TPMS issues
TPMS issues
I recently purchased a mounted set of wheels and tires from Discount Tire Direct. The sensors are already installed, all I had to do is bolt the wheel and tire up and torque the lug nuts. The front tires were recognized after 5 or 6 miles. The rears however have been on for 90-100 miles and the computer hasn't picked them up yet. Can anyone shed light on how the system works and what I might do to start the recognition process over or advance it in any way?
What is your tire pressure set at? Sometimes they won't connect if the pressure is too low relative to the factory setting. Try pumping the tires to 40 psi and see if that does it. If they connect, then you are fine to adjust the pressure to whatever level.
Good idea. Using the Flashcal, I've set the pressure threshold to 30psi. Is there a way to restart the learn process? I'll try a little more pressure this evening.
I don't think the Procal matters. Just air the tires up to 40. If that doesn't work, run over to your local discount tire. They can check to make sure the sensors are good.
I wish I saw this post before I bought my rims/tires from Discount tire direct. I am having the same issue. TPMS flashes fast for one minute then stays on steady. Over a week now. 2011 with 315 mhz. Never had an issue with old wheels and tpms. Will have to take it to local shop. No discount tires near me.
The tpms cost $210? Holy shit I would have opted out of that from the very beginning. That's ridiculous. Lol. Now I'm thinking I should sale my tpms sensors for half that. Hmmmm
