TPMS dash warning still comes on with flashcal?
So I just installed my Flashcal on my 2013 rubicon to turn off the tpms sensors, after i installed it the red dash light is turned off but the screen still says check tpms every time I start the jeep, and I have to hit the mode button every time still to make it go away. Any way to make this warning stop as well?
Make sure you have the latest update for your Flashcal, they changed how the TPMS disabler works a bit differently now and is much better. Hopefully that helps to fix the problem you have.
I just updated it before I installed it, it shows 0psi at all 4 corners and the red dash light is off now but it still says check tpms on dash on start up till i hit mode button.
I fussed with it several times until it went away. I downloaded the off-road TPMS module using Spark on the computer and then set the pressure to 23 lbs on program. That combination seemed to work.
I figured it out, I just disconnected my negative battery terminal for like 30 seconds and I guess it reset the dash warning , so far so good no more warning.
