Toyo A/T II in 285/75R16?
Old 02-14-2013, 08:18 AM
  #31
jadmt's Avatar
Originally Posted by JeepCopz
The weight of the vehicle will diminish the height a bit... just add more air.
Yes I know, I was hoping to get a measurment at normal psi not max psi.
Old 02-14-2013, 11:35 AM
  #32
SwooseGoose's Avatar
I'm running these tires in 35's on my jk. They are very quite, ride great and look great! Worth buying.
Old 02-14-2013, 03:11 PM
  #33
jadmt's Avatar
I ended up getting 285/75-16's. I like them so far. I wanted to go with the 295's but just was not confident with the running 34's and 3.21 gearing on an unlimited.
I have a 3/4" coil spacer otherwise stock suspension and I am happy with the look. On the Jeep with 34psi measure exatly 32" off the jeep almost 33"
Old 02-14-2013, 05:45 PM
  #34
FloridaFeMan's Avatar
Looks good! Would like to see a side shot with that 3/4" coil spacer up front. Did you lose any noticeable power with your tire choice?
Old 02-14-2013, 06:02 PM
  #35
jadmt's Avatar
So far only put 50 miles on getting the speedo/odometer dialed in with the procal but so far no loss of power and no hunting for gears. I live in a fairly hilly place (western Montana) so probably could have gotten away with the 295's but they did weigh about 10 lbs more per tire. mpg per the jeeps computer seems the same but I won't know for sure until I drain the tank and figure it out.
with the 265's
Old 02-14-2013, 06:36 PM
  #36
Thanks for the side shot "jadmt." Definitely looks good. I live in pancake flat Florida so I could get away with the 295s with the 3.21 gearing on my auto tranny. I am waiting on my procal to arrive to tighten up my shift points. Debating on front spacer to level out vs. 2.5" lift. Decisions.......
Quick Reply: Toyo A/T II in 285/75R16?
