Towing my wifes prius to texas from socal
Old 09-23-2013, 07:14 PM
Crawl_jk's Avatar
Default Towing my wifes prius to texas from socal
I have researched this, and understand the max towing capacity of the jk. My jk unlimited is a 2012 3 inch lift on 35's. 4.56 gears. Curb weight of the prius is 3,096lbs. How hard on the jeep would this be? its a 1700 mile drive.
Thanks
Old 09-23-2013, 08:43 PM
Sharkbait98's Avatar
On a trailer of flat tow?
Old 09-23-2013, 09:17 PM
nthinuf's Avatar
Stay under the 3500 lb limit and you'll have no problems. Go over the limit a bit and you'll still have no problems - other than any liability issues you run across, of course.
Old 09-23-2013, 09:21 PM
Crawl_jk's Avatar
Looking at a trailer as of now. Any input on the two?
Yeah I have noticed the liability issue. I should be good at about 3500lbs. Not trying to set a land speed record on the way there
Old 09-23-2013, 09:32 PM
nthinuf's Avatar
I have taken several 10-12 hour drives from Colorado down to Texas and back up, towing either a boat or a 6x12 enclosed uhaul. Both are over 3k, depending on load could be closer to 3500, and have had no problems other than the general gutlessness of my 3.8. No issues with braking or swaying or over-heating.
(2008 4door auto, factory tow pkg, trans cooler, 4" lift, 35's, 5.13's & 5.38's).
Old 09-23-2013, 09:34 PM
Crawl_jk's Avatar
Ok so I should have no issue. Even without a trams cooler?
Old 09-24-2013, 04:03 AM
karls's Avatar
If you've got an auto it's generally recommended to have a trans cooler in the first place regardless of towing or not. It certainly wouldn't hurt to get one, but without one, be aware that you could be setting yourself up for many stops to let the fluid cool down.
You say you want to tow it- what's the weight on the trailer? I think you'll come out closer to 4k at least if you do a full trailer. A dolly would be more in line with keeping the weight minimized next to just flat towing.
Sent from my DROID4 using Tapatalk 4
Old 09-24-2013, 04:56 AM
Phrogmech46's Avatar
I wouldn't even consider your plans to tow that much, that far, and over max gross. I'm sure you can do it but it doesn't make it a good idea.
Old 09-24-2013, 05:45 AM
thegoat's Avatar
When I made a cross country move a year ago I looked at towing or getting the car shipped. The u-haul and gas where about as much as shipping the car, I opted to have my car shipped for $500. It looks like San Clemente to Texas will cost about $565 for the trailer and putting your car on a truck is about $825 via national transport llc. I would look at shipping your car and save the headache and gas.
Old 09-24-2013, 09:49 PM
DROELLE's Avatar
Even saying the word Prius makes me puke in my mouth. When moving there's always some things that are just ok not to takin with you. Might throw this into that idea box of "ok to leave behind" lol! Jk you'll be fine. I'd straight pull that...car....
Sent from my thread killing iPhone
Quick Reply: Towing my wifes prius to texas from socal
