Torx bolts
On your doors? Hood? Guessing the doors. I'd say get some touchup paint or if you're able to afford it, take it to a body shop before the cancer spreads. My hinges are showing some rust, guessing from the rocks being kicked up on the trail.
Thanks,
Steve
Thanks,
Steve
Doors and hood. Slightly more on the hood. Not bad you have to be a little obsessive to notice it but like you said it's not going to reverse on its own.
Clay bar. Most likely the rust is just metal filings from the hinges that are imbedded in the paint. I had the same issue along with the hood hold downs on my white YJ. Clay bar took it all off. I used this kit...
http://www.walmart.com/ip/California...ystem/15137646
Clay bar. Most likely the rust is just metal particles from the hinges that are imbedded in the paint. I had the same issue along with the hood hold downs on my white YJ. Clay bar took it all off. I used this kit...
