Torque specs for wheel spacers????????
Old 01-20-2012 | 01:40 PM
mikegp's Avatar
Default Torque specs for wheel spacers????????
Hey Y'all
I have the 1.5" spidertrax wheel spacers. Does anyone know the torque specs for install them???
thx
Old 01-20-2012 | 02:29 PM
tnt008's Avatar
It is 90 ft lbs
Old 01-20-2012 | 02:41 PM
RubiconOrBust's Avatar
Project JK write up on your spacers: 95 lbs.
http://project-jk.com/jeep-jk-write-...ation-write-up
Old 01-20-2012 | 04:19 PM
mikegp's Avatar
ok i checked the write up and it says 95 just curious where the others got 90, will it make much of a difference?
Old 01-20-2012 | 04:23 PM
woodyvw9's Avatar
Veteran: Coast Guard
My Spidertrax instructions say 80-90 ft-lbs.
Old 01-20-2012 | 05:02 PM
Jaraxal's Avatar
I just installed a set on my 2011 JKU Sport last weekend. The instructions that come from Spidertrax says 80-90 lbs. I torqued mine to 90 lbs.
Old 01-20-2012 | 05:16 PM
fadeout's Avatar
I did mine at 100lbs and they've been fine for a long time. I read in a thread a long time ago that's what the actual owner of the company torques his to.
Old 01-20-2012 | 08:47 PM
Sahara_Maverick's Avatar
I also used 90ft.lbs on mine, based on the instructions that came with it. Also used the red "thingy" they sent with it.
Old 01-21-2012 | 05:12 AM
Willybugman's Avatar
Running mine @ 100lbs with red loctite on the threads holding the spacer to the hub. Make sure the hub and spacer are clean where they mate together to get a good seat. Clean the threads with brakekleen or alcohol (dont use BEER) and dry before putting on a couple of drops of loctite. Do not use threadlocker on the wheel studs.
Old 01-21-2012 | 08:07 AM
Ryan0260's Avatar
I run mine at 90 lbs. A few more wont hurt
