Torque for Rock krawler jam nuts
Old 09-04-2013, 05:10 PM
AaronJK's Avatar
It's 1 5/16 for the small ones, 1 1/2 for the big. It's loose, but correct. I have put everything I have into these without any damage, it's the right size.
Sent using my SuperSmartThinky Phone
Old 09-05-2013, 12:24 AM
ScrappyJkur's Avatar
big adjustable or a pipe wrench and crank on it, havent had any probs out of mine
Old 09-05-2013, 01:43 AM
Bonedoc's Avatar
I have large open end wrenches in that size. I put them on and put all of my 270lbs behind it till it absolutely won't budge. No problems so far, just man handle it!
Old 09-05-2013, 02:35 AM
kjeeper10's Avatar
I have a huge adjustable I bought At harbor freight. $25 I think I paid for it. Things a monster
Old 09-05-2013, 04:47 AM
JayCW's Avatar
Originally Posted by j3r3myjam3s13
So what im hearing is........nobody has a good way to properly toque them. I bought a 3/4" torque wrench and plan on using a 1-1/2" crowsfoot to get it done. Was hoping someone had tried something similar to this already
I used this setup and found it hard to keep the joint square while putting enough force on it. Agree with most with "just torque the crap out of them" and you should not have any problems.
Old 09-08-2013, 08:47 AM
fredrok's Avatar
I have very few things I did not like about my RK lift. I push their product every chance I get, but this was one of my concerns during my install. IIRC, almost every one of my CAs were not drilled/threaded true so what you end up with is the jam nut only contacting about 25% of the "jamming" surface. This would certainly require much more torque to keep from coming lose than if the entire jam nut surface were in contact.
Old 09-08-2013, 08:54 AM
j3r3myjam3s13's Avatar
Originally Posted by fredrok
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=495833"/>
Interesting, did u contact them about this? They seem like the kind of company that would want to fix this issue......gotta check mine now while they're still in the box
Old 09-08-2013, 09:37 AM
fredrok's Avatar
I did. They basically said "don't worry about it and crank them down". To be fair, I've not had any come lose, but it still isn't "correct".
Old 09-08-2013, 10:51 AM
Wow! That truly surprises me! Sorry to hear that, guess i'd just keep an eye on it then, not sure what else to say
Old 09-08-2013, 11:05 AM
fredrok's Avatar
Meh, I'm not gonna worry too much about it since they haven't been coming lose. But I figured at least I've let them know in case I were to have any of those issues.
Quick Reply: Torque for Rock krawler jam nuts
