tom woods 1310 read drive shaft vibration
#61
So, I'm a little confused on this. The stock setup technically isn't either of those since stock is an rzeppa not a single cardan (image 1). I don't completely get why an rzeppa/single cardan would require a different set of angles (specifically the pinion angle) than a double cardan/single cardan. Is it just the mass of the spinning double cardan that gets wonky when its spinning faster than normal?
For what its worth, this isn't purely academic for me. I've got my front driveshaft off right now because the boot on the cv failed. 3.5" aev lift using the aev brackets so my pinion is 6 degrees off of perpendicular to my driveshaft (ie, 91 and 7). So I'm faced with either repairing the stock shaft (no clue when the boot ruptured) or figuring out how to properly cant (cast?) my pinion and buying a double cardan. Is finding someone (woods) to build a shaft with a double cardan on each end a reasonable tactic?
Sorry for the novel.
As far as pinion angle with front aftermarket double Cardin Shaft, it's just trial and error to get a balance between pinion and castor.
I would start right around 2* pinion which in turn should give you about 4* castor. Just depends on if you get any vibrations .
Less castor more pinion and vise versa.
#62
I probably forgot to mention it, but there is a bunch of info right on Tom Woods website (Tech Info area, Driveline Geometry 101 section...) that answers your question.
Tom Wood's Custom Drive Shafts - Tom Woods Custom Drive Shafts Custom Driveshafts Specialist
