tom woods 1310 read drive shaft vibration
Old 12-29-2014, 11:33 AM
  #41
ronjenx's Avatar
Originally Posted by going_commando
https://www.youtube.com/watch?v=JgmXg5EIF8w I watched this hence why I was trying to match the TC and Pinion angle. I will be purchasing adj uppers tonight. I can't stand this annoying vibration
The situation at the beginning of the video is different from yours. In the video, the drive shaft has a single cardan at each end. In that case, the angles have to be the same on each end.
You have a double cardan at the t-case, correct?
Old 12-29-2014, 11:36 AM
  #42
going_commando's Avatar
Correct I have the Tom Woods 1310.
Old 12-29-2014, 11:40 AM
  #43
ronjenx's Avatar
Like this?
I put the angle finder on both ends of the DS and the measurements are the same
Putting the angle finder on each end of the drive shaft, and finding the angles the same, indicates you are not understanding the point.
You need to know the difference in angles between the drive shaft, and the pinion. It should be straight like the photo/drawing a few posts ago.
Old 12-29-2014, 11:43 AM
  #44
Ok so looking at this picture basically the pinion angle and DS angle need to be the same?
Thank you for your patience
I was never good in geometry
Old 12-29-2014, 11:48 AM
  #45
ronjenx's Avatar
Yes. A line drawn through the drive shaft should continue straight through the pinion shaft.
Old 12-29-2014, 11:51 AM
  #46
OK, I finally got it.
Now, To fix the problem, In your opinion do you think only upper adj. will fix this issue or should I also order lowers?
Old 12-29-2014, 11:58 AM
  #47
Using Paint and drawing a line makes sense.
Again thank you for your help, It is greatly appreciated.
Name:	JEEP DS GEOM.jpg
  #48
ronjenx's Avatar
At this point, I'll bow out and let the adjustable control arm experts continue.
Old 12-29-2014, 12:02 PM
  #49
Rebar-7's Avatar
Thank God.. I personally would do uppers Adj CA's
Old 12-29-2014, 12:04 PM
  #50
Rebar-7's Avatar
Thanks for your help Ron....".
Quick Reply: tom woods 1310 read drive shaft vibration
