Tolerate Negative Camber?
After adding a Teraflex 2.5 coil lift with 35s Sunday and getting an alignment today, my front passenger side has a -1.1 camber.
If I assume it's a bent C then an adjustable ball joint can fix this. So should I just get the passenger side or do I need both? Will welding on ORE's sleeves and gussets do anything besides causing this to bend further? I'd still need the ball joints which could end up being over $1000 with labor.
Assuming it's a bent tube, is it just worth leaving and tolerating it until it breaks for a Dynatrac ProRock 44 housing? For $1000 more will this be that much better than ball joints and welding? Ideally this would be best, but should I just wheel the stock 44 housing hard until it breaks or would this cause greater problems in the future?
Thanks!
Thanks!
Your only out of spec by 1/2 degree. You could just have bad ball joints. Had mine replaced under warranty at 36k miles. I can't see it costing a grand to have the ball joints replaced. Jack it up on the front axle and stick a board under the tire. If you get any movement in the tire/wheel when applying pressure upwards on the board, you have a bad ball joint. Camber spec is -.10 to -.60 degrees. Whad did the drivers side read? Just curuious. My passenger side read -1.1 also before I had the ball joints replaced. FWIW, the factory ball joints are shit with their plastic inners. I just had it done w OEM replacements because it was free. I will replace them w Moog BJ's when the OEM pieces of shit fail again.
Ha! My driver's side was the same! Did you get any movement when prying up under the tire? You will definately feel it. Mine had a "click" in it when I pryed upwards.
