TMPS Tire Swap
Old 10-19-2016, 08:36 AM
sandbandit13's Avatar
I bought the new sensors from a jeep dealership. So I hope they put the right year on. My jeep jk is a 2015.
Old 10-19-2016, 08:37 AM
jedg's Avatar
Originally Posted by SF_E60
Just make sure it's the same year jeep. I bought some used wheels/tires from a local member I forgot what year his was but mine is a 2012 and after I put them on TPMS sensor was triggered. I had even asked the owner if the TPMS sensors were working and he said yes. Never had a problem. I took it the dealership and even their reader couldn't pick up the signal. I ended up just buying TPMS sensors online for my year JK. Problem solved.
Yeah... there's a split in the years I think (like I said above).
I know that TPMS from a 2014 worked on my wife's 2016
Old 10-19-2016, 08:38 AM
SF_E60's Avatar
Originally Posted by Smudgeontheglass
2013 got an optional advance monitor that you could see the TPMS pressure reading for each tire but I believe it uses the same sensor as before.
Are you sure? I was told it uses a different frequency that's why the TPMS sensors didn't work for me.
Old 10-19-2016, 08:59 AM
nosnhoj1's Avatar
2007-2012 JK's use a 315mhz tpms sensor and 2013-2016 JK's use 433mhz.
Old 10-19-2016, 09:19 AM
SF_E60's Avatar
And... there you have it which is why his newer TPMS sensors didn't work for me.
Old 12-11-2016, 07:10 AM
1mortician's Avatar
Default Sport to Sahara
I swapped my 2014 sport wheels for 2014 Sahara wheels, went fine, and the tires read the pressure for the first 5 miles. then the system reported an error with the read out __ __ . Should I have this reset at a tire place? I drove for 10 miles at sustained speed to see if it would reset?
Thank you for any advice!
Old 12-11-2016, 08:06 AM
SidewaysTA's Avatar
Good to know.
Quick Reply: TMPS Tire Swap
