Tires and Spacers
You could run 285 75 17 on stock wheels 11.5 width no spacers needed just a couple of washers behind steering stop bolts so they won't rub front sway bars at full steering lock. Minimal steering radius loss by shimming out stop bolts.
Besides wheel spacers put undo leverage force stress on axles, bearings and steering joints resulting in pre-mature wear or bent axle ends.
Besides wheel spacers put undo leverage force stress on axles, bearings and steering joints resulting in pre-mature wear or bent axle ends.[/QUOTE]
Are you saying that with wheel spacers you will cause these issues. Because wouldn't a wheel with a longer offset throw off the balance of the axle?
You are correct. Any extra wear and tear will happen whichever way you choose to move the tires out. Whether it is stock rims + 1.75" spacers for an effective 4.5" backspace, or new rims with a 4.5" backspace - you have moved the tires out by 1.75". The negative to spacers is that there are extra parts thrown in the mix that need to be installed correctly, and maintained.
So is there a way to put bigger tires without put extra stress on the axles or that just something that comes with the territory, because if that is the case then I'm fine with that, I wanna redo the gears, lock and strengthen the axles when I put 35s on it and that will be until it is paid off.
Just my opinion, everyone has different ones on spacers, but I ran the rough country's of my buddies and I hated the ride, it felt like it had a shimmie in it, maybe cause it was the cheaper rough country brand, all I know is I took them out and it rode perfect I just couldn't turn to full lock. I've since just bought 4.5 inch back spaced wheels and it rides like stock. So if you've never had spacers on you might wanna think about that also
From what I've read, it's different with each tire size/brand. I have 1.5" spacers on stock wheels with 35s. Removing the air dam (fake plastic front skid) stopped the rubbing issue. Jeep also looks better without it
