Tires rotated...shimmv at 40mph
Old 01-31-2011, 05:37 PM
maine07jk's Avatar
Default Tires rotated...shimmv at 40mph
I just had my tires rotated for the first time. Its been about 5000 miles. Now I notice a shimmy in the steering wheel starting around 40 then goes away. Any ideas?
Old 01-31-2011, 05:47 PM
jkrub2008's Avatar
maybe the rim needs be balanced good luck
Old 01-31-2011, 06:48 PM
Merlin4979's Avatar
Originally Posted by jkrub2008
maybe the rim needs to be balanced good luck
I agree. Just about every time I've rotated my tires, I needed to rebalance them. This is usually the case when the shimmy is speed-specific. I'd go have that done first and then see what happens.
Old 01-31-2011, 07:20 PM
nvrenuff's Avatar
Everytime I rotate my tires I at least have the fronts balanced or I have the same problems you described. Balance for sure.
Old 01-31-2011, 08:54 PM
daggo66's Avatar
Also make sure the lugs are properly torqued.
Old 01-31-2011, 11:11 PM
Rhino64's Avatar
I had that problem in the past its always been balance related.
Old 02-01-2011, 06:10 AM
ClaytonT's Avatar
Could also just be the tire wear evening out. Might go away by itself.
Old 02-01-2011, 06:38 AM
Jeepsty's Avatar
I rotated my tires last week and had the same thing at 40 mph . Took it to get the tires balanced and both tires had to have weight added. 1 was 3 ounces out and the other was 10 ounces. Drives great again
Old 02-01-2011, 07:01 AM
spanishgoose's Avatar
I had the exact same thing last week, i will have mine rebalanced and see what happens.
Old 02-01-2011, 10:08 AM
Lomax-dtl's Avatar
I had the same problem two weeks ago. Then after I got my tires balanced it went away. Hope this helps
Quick Reply: Tires rotated...shimmv at 40mph
