Tires/rims
Tires/rims
Will the rugged ridge 17 X 9 rims fit on a BFG 285/70r17 km2? I know the r17 means the 17 inch rim but the X 9 part im not sure.
thanks
http://www.quadratec.com/products/92604_201_07.htm
thanks
thanks
thanks
Its an effect of squeezing or pushing out the sidewalls of the tire by changing the wheel width. A wider rim can provide a larger footprint, and have a slight effect on the diameter of the tire. A narrower rim will cause a smaller footprint, as some of the tread is being pulled up off the road surface, and has the effect of making the tire slightly taller.
JK-Forum Founder
Yeah you can certainly change the contact footprint by changing the air pressure as well. I think most of the effect is actually visual. A wider rim will make it look wider by pushing out the sidewalls. The TSL's that I have on my J10 as 12.50 wide, and on 8" wheels they look taller and narrower, on a 10" wide wheel they look shorter but wider. But its basically visual.
