Tires and Gears
Old 11-25-2009 | 09:45 PM
Dog Doc's Avatar
So... I am a newbie but, will a light (weight) 35" be about the same as a heavy 33" tire? Will the sluggish drivability be about the same between the two?
Old 11-26-2009 | 12:33 AM
smcastillo's Avatar
weight isnt the only factor, wind resistance on a larger tire, the weight being farther from the center of the axle
Old 11-26-2009 | 12:54 AM
woodweavil's Avatar
You can run 35s with a minimal lift. and do it without changing gears, how ever its like driving a yugo in rush hour traffic. not a lot of fun. You live in SE michigan. The Guy who did mine is a member tuffjarhead, is his Handle on here. 175 per axle. plus a 100 to put on the C gussets and the LCA skids Gears are 500 from David at Northridge
