is this tire wear normal!?!?!?
Old 03-28-2011, 11:45 AM
jonnyringo893's Avatar
Default is this tire wear normal!?!?!?
ok, here are some pics of my tires, they seem to be wearing unevenly in a weird way. i just want to see if anyone else has seen this before. my jeep in an 08 2dr with 35in pro comps. i am running 35 psi. i have emailed pro comp but they arent much help at all. my first set i had before this one had no issues at all and i have not added anything to the jeep since then. btw i have had this set on for less than a year. i think next go around i will try something else! here are the pics
Old 03-28-2011, 11:48 AM
4cyturbowrx's Avatar
That's called cupping, did u ever rotate your tired......
Old 03-28-2011, 12:07 PM
every 3000 miles with oil change
Old 03-28-2011, 12:09 PM
arasco85's Avatar
I rotate mine every three and also does this. Mine only seems to do this on driver side front. Mine are km2
Probably depends on the kind of tires
Old 03-28-2011, 12:14 PM
4WHLN's Avatar
35 PSI seems a bit to much and that might be your problem. I have mud grapplers and I usually run 28 PSI in them. I recently went to 33 PSI since I've been driving alot of highway to see if I would get a little better gas milage and mine have started to cup. But I may be wrong on this.
Old 03-28-2011, 12:27 PM
arasco85's Avatar
Every tire is doing this?
Old 03-28-2011, 12:35 PM
GreenJK07's Avatar
Every time I change my oil, I rotate for that reason. Plus they will last a lot longer!
Old 03-28-2011, 12:42 PM
Mark Doiron's Avatar
Can also be caused by a bad shock absorber. When bad it will look like diagonal bands all across the tire. Tires will feel squirely when it is bad; can be dangerous to drive because of poor tread contact with road. My DC FC IIs did that.
Old 03-29-2011, 10:18 AM
JK.sahara's Avatar
ive got 35x12.50x18 pro comp xtreme mud terrain and i rotate every 5000 and i run 50 psi. they are about 20,000 miles and are wearing beautifully. i might try running more air
Quick Reply: is this tire wear normal!?!?!?
