Tire sizing question...help
I put a 4" suspension lift on my jk this past weekend and Im ready to upgrade from my stock tires.
I want to keep my same stock wheels. The guy who helped me install my lift told me I would need some bolt on spacers. so I bought those, but Im not to sure which tire size is going to be suitable for the stock wheel.
Im thinking either the 315/70R17 or the 35x12.50R17???
Im shopping around right now and looking into the Goodyear MT/R Kevlar or the BFG KM2. Its my everyday driver so im still undecided if I should even go with MT or just do AT.
Im more of just the weekend warrior!!
Please let me know, some input would be appreciated
As far as AT vs MT vs one of the hybrid 'aggressive ATs', that's completely up to you.
Lots of us on here running 12.5 wide on stock rims with spacers. I've wheeled lots of times, and had them for a couple years, no problems at all.
If you don't wheel much, go with ATs. They are quieter and will last longer, and still look cooler than street tires.
I assume you have already considered the loss of power with larger tires, but if you haven't, you should check into it. Your differential gearing is set up for smaller tires. A lot of us just live with it, but regearing might be in order if you have the budget.
I gotta disagree.
