Tire Rubbing issues
Tire Rubbing issues
With a 4" TF long arm lift, dana 44 and a beadlock wheel with 3.5 BS, which is the largest size (diameter and width) tire I can run without rubbing and without using any spacer both on and off road with the the tires at low PSI
From you sig you are running 35s as of now. Have you fully flexed your suspension and measured to see how much room you have left. Thats the best way to tell for sure.
I have 35 now, but I have Nitto 38 in mind and they are 15 wide. I the suspension are fine, the problem is when at full turn, does not look I have too much space left
