tire rotation
tire rotation
Pre problem handling....Zero.. Jeep rolls down the road like a champ handles perfect. Tires balanced and alignment is correct. Tires show even wear and very happy with jeep.
current problem....rotated tires after 2500 miles and jeep still handles great unless I travel a certain portion of this blacktopped roadway thats grooved from years of heavy semis running over it. The jeep wants to wonder back and forth something fierce.
I had zero issues before the rotation but now its acting like a completly different Jeep.
This is how I rotated the tires.. right front switched with left rear....left front with right rear. I know this is not ideal for a correct rotation but could this be my problem..I noticed the handling problem as soon as I drove down that grooved roadway. Took it the place that balanced my tires and got the now front tires rebalanced and still having the drifting problem.
Help
Spec for my jeep
315/70/17 Mickey M/T
3 inch lift
Help
Spec for my jeep
3 inch lift
Check Draglink, track bar & tie bar bolts with a wrench.
If they are tight, get your current front tires rebalanced with a Road Force balancer.
(Some tire shops don't use Road Force balancers, and it's more accurate)
---edit tie bar/ track bar---
If the only problem is your tire rotation, then one (or more) of tires are unbalanced or out of round.
Find a shop that can "dynamically" balance your size tire.
Some shops only have a machine big enough to handle car tires, but they don't tell you.
Make sure they do it the right way by removing all weights and then rebalancing.
Pay attention if any tires (particularly) the spare requires a lot more weight than the others.
