Tire pressures
Tire pressures
So my lift came in today and my wheels will be here tomorrow! I purchased 17" AEV Savegre wheels in black and in the description it said they are compatible with TPMS.. As far as the stock wheels go on my JK right now, they don't seem to have sensors in the wheels just rubber valve stems so how am I supposed to set up the TPMS with my new wheels? Any advise?
Just to be clear, do you have TPMS in the vehicle (any type of readout)? The newer TPMS sensors use the standard rubber valve. If you have pulled the tire, you'd know if it had sensors though.
Good Call Invest2m4
I haven't dismounted my old tires yet, but judging by the outside they are rubber.. And as far as a readout goes I do have a tire warning light which comes on for about 10 seconds every time I turn my headlights on (installed HIDS) .. I just want to know the easiest way to take care of the light with aftermarket rims on..
Here this Might help also. (visually) http://www.tirerack.com/tires/tirete...jsp?techid=152
Just looked at your profile. If you have a 2014, then you have TPMS. Your valves will be rubber, like any standard valve. You have a few options:
1. Don't use TPMS anymore (you'll need a Procal to shut it off, but you need it anyway if you are going with bigger tires, so you can calibrate the speedo).
2. Have a tire shop pull the sensors from your current wheels (they can do it by just breaking the bead). Then you just need to buy new rubber valves that accept the sensor. I just did this with my beadlocks. Belle Tire sold me 5 new valves or $15.
3. Buy new sensors. Probably the most expensive option. On a 2014, you may be closer to $200 for a set of 5. I honestly have not looked.
Somewhere in your info center in your Jeep, it should actually tell you how much pressure is in each tire. Personally, I like the convenience.
Correct..
Found this out when I swapped tires.. He swapped spare has the rubber valve stem where at all the other tires had the metal stems, Had merchants tire check this out for me.
However, The only thing I was able to locate was many jeep wrangler owners are use a Procal or superchip system to set their TPMS to ( 0 )
