Tire pressure
Old 08-13-2012, 04:31 PM
EzK
EzK's Avatar
Max tire pressure is for carrying the max load. Heavy duty truck tires(f250/350 type trucks) have very high load capacities and need tires that can handle it. My work truck's tire max is 80psi and I run them at 70.. it rides like total crap but it is hauling heavy trailers, tools, and a 100 gallon diesel tank around all day. The 20,000 pound Freightliner tires run at 105psi, you get the idea.
On a light Jeep these beefy tires can be run at lower pressures and support the jeep more comfortably.
Old 08-13-2012, 04:33 PM
Kalamari's Avatar
My buddy runs his 35's at 28 on the street and 12 on the trail.
Old 08-13-2012, 04:34 PM
Zenabi's Avatar
Thanks for clearing that up
Old 08-13-2012, 04:36 PM
jayandleah's Avatar
Originally Posted by Zenabi
Why is the max pressure so high?
Max air pressure is like the weight rating of a hitch. A hitch is rated for the max load it can carry before safety or failure becomes a factor. It's just a measurement of the maximum amount of air that the tire can handle. Whether you run a tire capable of 65 or 50psi typically your air pressure will remain the same around 30-35psi. However if a tire is an E load rating sometimes you may run a little lower air pressure to compensate for the extra steel belting and compound of the rubber. But we are probably only talking 2-5 psi.
You have to keep in mind that a tire is meant to be used on a variety of vehicles.
For example my 2500hd crew cab has 285/75-16 duratracs and our JK has 285/70-17's. Same max psi rating but I run 50psi on the truck and 30 on the JK. Only because the truck weighs sooo much more.
Hope this helps.
Old 08-13-2012, 09:08 PM
07Rubi's Avatar
Default 37's and Tire Pressure
for a 35, i would say about 30 psi
Putting 37's Trail Grapplers on an Expedition Modded rig as we speak. I went with the Nitto's on your reco WOL, based on the sidewall strength you mentioned etc. My JKU has a lot of extra weight. AEV front bumper and Warn 9.5, AEV rear bumper with gas storage (plus 5 gallons of potable water in the bumper), 60" hi-lift, pull-pal, gobi rack with 135lb Maggiolina RTT with 30lbs of gear inside, ARB fridge and 2 drawer rear area only storage. Full armor underneath, and a few other things. What air pressure do you think I should run the Nitto 37's at with all that extra weight?
I'll be on beadlocks with on-board air for off-highway.
Thanks in advance.
Old 08-15-2012, 06:52 AM
07Rubi's Avatar
Default Nevermind.
Originally Posted by 07Rubi
Putting 37's Trail Grapplers on an Expedition Modded rig as we speak. I went with the Nitto's on your reco WOL, based on the sidewall strength you mentioned etc. My JKU has a lot of extra weight. AEV front bumper and Warn 9.5, AEV rear bumper with gas storage (plus 5 gallons of potable water in the bumper), 60" hi-lift, pull-pal, gobi rack with 135lb Maggiolina RTT with 30lbs of gear inside, ARB fridge and 2 drawer rear area only storage. Full armor underneath, and a few other things. What air pressure do you think I should run the Nitto 37's at with all that extra weight? I'll be on beadlocks with on-board air for off-highway.Thanks in advance.
Found the answer in other tire pressure threads. Apologies.
Old 08-16-2012, 06:31 AM
Zenabi's Avatar
I have been running 31 pounds in my 35's on my unlimited an it seems to be doing fine
Quick Reply: Tire pressure
