Tire pressure
discount tire had my Falken 287/70R17's at 40. I lowered them to 35 and it does feel better. After reading earlier post thinking I might go even lower.
Originally Posted by ronjenx
Take another look at the sidewall. That's the max rated pressure at full load. Normal pressure is on the sticker on the B pillar.
It's probably a misguided attempt to decrease their liability.
I don't know but I don't want my brand new tires wearing all jacked up so I lowered the psi to around 35ish might move it down a little more I'm going to see how it wears the new rubber teats down now.
I contacted the Nitto Tire Company directly about what tire pressure their engineers recommend for 285 70 17s on a 2012 Wrangler Unlimited 4 dr and this is what they said:
Thank you for contacting Nitto Tires.
In response to your question, we recommend 44 PSI for your Trail
Grappler [285/70R17] on your 2012 Jeep Wrangler Unlimited 4 Door.
Please note that this number is a calculated estimate, please feel free
to make any adjustments until you have achieved a comfortable ride.
If you have any other questions, please feel free to contact us back at
any time.
Thank you,
Nitto Technical Department
any time.
Thank you,
chalk test. running 34 psi on my 315/70/17s. 285/70/17 would probably run at 35 or 36 psi.
depends also on if you want a nice cushy ride or fuel savings as more psi = less resistance
Proper wear/tread life depends on more than just tire size. It also depends on rim width, tread pattern, the true size of the tire, and vehicle weight. The chalk test is the best way of checking to see if your tire will wear nicely. Do the chalk test to get them to where they wear evenly and then adjust for comfort/gas savings. You can run your tires at 65 psi (if they're rated for it) and save some fuel, but you'll also burn off the center tread far sooner and have to buy 4 new tires that have near perfect tread on the outer edge. Also keep in mind that if you tow a trailer/camper or put 500+ lbs in the back of your rig for a trip then you will want to add some more air to the rear tires. Basically, use what others have said as a reference and then adjust for your rig. You might have 1,000 lbs more or less on your vehicle than what they have. Recheck whenever adding/removing significant weight or changing rims/tires.
![Cool](https://www.jk-forum.com/forums/images/smilies/cool.png)
