tire opinions with these black steelies
Old 09-09-2007 | 11:14 AM
Rex's Avatar
Rex
Default tire opinions with these black steelies
Have Stock Unlimited X, what black wheels and 33's.
Here is the look of wheel I want, are these a descent brand?
http://www.quadratec.com/products/92601_4XX_A_PG.htm
As far as tires I want AT's, but may opt for some off roaders if they are more on the highway friendly side. With the 5" backspacing on the wheels above what would you recommend as far as tires? How much would they stick out from the fender?
Thinking about these at 33x12.50R16 width 12.4, but not sure about the rub with no lift:
http://www.quadratec.com/products/92608_00X_PG.htm
Old 09-09-2007 | 11:23 AM
bsack's Avatar
same size i just ordered with the procomp series 97s(like the Cragar). Alot of people already rollin that size and could tell ya better. Discount Tire is the best price I found though
Old 09-09-2007 | 11:30 AM
Rex's Avatar
Rex
tried discount tire only getting like 3 options for wheels. Not even seeing pro comp when searching by brand, maybe out of stock.
Old 09-09-2007 | 11:36 AM
bsack's Avatar
yep they carry procomp. Their website is a mess, wont allow you to click on their procomp wheels. I got 16X8 soft 8s with a 4.2 bs to match up with the tires. Best tire outfit ive dealt with. Had tried a PNW tire outfit and the guy tried to sell me a blingy 20" wheel He asked me why I wanted to 'downgrade' from my 18s Id call DT and see what they can do for ya
Old 09-09-2007 | 11:58 AM
Rex's Avatar
Rex
I've never seen twinkies or bigger on a jeep that I liked. The most disgusting thing I've seen was a lowered TJ with 14's and skinny tires. It couldn't go over a curb. I will call DT tomorrow thanks!
Anyhow, I'm still noobish on the tire width and backspacing etc...
If I get a 16x8 wheel then how wide can I go with the tire?
And how expensive is it to increase the backspacing if I want the wheel to stick out alittle more?
Old 09-09-2007 | 12:07 PM
bsack's Avatar
And how expensive is it to increase the backspacing if I want the wheel to stick out alittle more?[/QUOTE]
Stuff I dont know much about. I went with 33x12.5r-16 with 16x8 but beyond that I havent a clue. I bet ya that someone will be speaking up soon. Hope I helped alittle
Old 09-09-2007 | 12:19 PM
easttnruby's Avatar
I wouldnt go any wider than 12.50 with an 8" rim. As far as $$, it shouldnt be any more for diff backspacing. To my knowledge diameter and with are the only thin that should change price. hope that helps out and good luck!
Old 09-09-2007 | 01:21 PM
mikeyfl's Avatar
im going 13.50 on my 15x8s.
Old 09-09-2007 | 01:24 PM
Rex's Avatar
Rex
What wheel/tire?
Old 09-09-2007 | 01:27 PM
Rex's Avatar
Rex
Wish someone had 16x10 in those cragars or the pro comp 87's, wonder how wide you could go then O_O
