Tire almost came off...
You did loctite the bolts right? I check the bolts and re- torque them every oil change which is every 3k and honestly they haven't budged. And absolutely do not drive it the way it is...have it towed
Yes, I did but since I installed the nut the wrong way, I guess it didn't matter. Now when you check your spidertrax are you getting any movement and if you did do, do you reapply that stuff? Because it does " break the seal" once you retighten them correct? Or does it even matter.
I wouldn't recommend tightening them repeatedly with an impact, as you have no idea what torque is on them and you could end up yielding the studs. Any decent impact is capable of torquing the studs beyond what they are capable of and could result in the studs failing.
+1 I use the impact wrench with a Torque Stick (70lb.ft) and then tighten with the torque wrench. Also do this for all other bolts.
