tips for removing stock control arm bolts?
hey all,
im about to install my AEV drop brackets as i just installed a teraflex 2.5" coil lift on my JKU and im looking for advice on removing my stock control arm bolts.
My JK is already 6 years old and the bolts havent moved since its build date and i cant get any movement on them. I already let them soak in some wd-40 and even borrowed a friends breaker bar.
Any other suggestions for removing these!?
Any tips or suggestions would be much appreciated.
-Adam
-Adam
A lot of guys fight and fight with control arm bolts whether taking them out or installing them. If you get the holes to line up then they usually come out with ease. The way to get them to line up is to raise the front or rear of the differential. Usually you have to lift on the pinion side. Once the Jeep is lifted and you have the nut off the control arm bolt put a jack under the pinion. Start raising it slowly and the bolt will usually come out with just pulling on it. Good luck.
Think he's having issues getting the old bolts out. Not getting holes to line up.
I used a cordless impact wrench that is capable of 450ft Ibs. If you don't have an impact, try heating the bolt up a bit or PB blaster as others have said.
If all else fails, get a bigger breaker bar. Worst case, order the northridge bolt kit and then just cut the bolts off!
Use the handle of a floor jack or a long pipe and slide it on the breaker bar for leverage. I need to get myself a cordless impact but gone this long without one...
When I took mine off I just used a socket wrench and handle from my floor jack. Shouldn't need to but liquid wrench can help. Dead blow hammer to break up corrosion if you have to.
I installed these a while back. Didnt have much of a problem getting most of the bolts out, and dont have any advice that has not already been stated. But, The upper control arm bolt on the passenger side will run into the exhaust when you start taking it out. I had to cut the bolt and buy a new one. Just FYI.
Also many people say these worked for them, but they didnt for me. Now i have LCAs...
Haha thanks for all the suggestions guys. I've tried an impact to no avail but pb blaster sounds like my next choice
I'm more so worried about my front right upper near the exhaust as I can't fit an impact or breaker bar up there..anyone have any trick on getting that one out?! Thanks
