Tips for Removing/Repairing Leaking Transmission Lines?
My crimp fittings are leaking however; I have installed a B&M cooler so the dealer recall fix is not an option. After researching various threads on JK-Forum, I have decided the best fix is to:
1. Remove the lines from the Jeep (for better access)
2. Cut off the crimped ends with a tubing cutter
3. Replace with 3/8” tube-to-barb adapters
My JEGS shopping cart is shown below.
Any tips from other Jeepers for performing this fix? It looks like the lines should come off easy and that will make the job easier.
Don't know
This isn't something I've done, but when asking a friend he suggested tossing out the hose that comes with the kit and using stainless steel braided hose. Personally, I don't know if its worth the extra cost, but he looked at it as insurance.
Has anyone had success replacing the lines under warranty with their aftermarket cooler installed?
Transmission Lines Repair
So how did your repair go. I do not see an update on it. I just bought my 2010 unlimited and I have the same issue. From what I have seen your fix seems to be the best solution. I would love to hear how it went and lasted. Thanks
