The time to mod is comming
Old 12-19-2013 | 01:49 PM
mikestoick's Avatar
Default The time to mod is comming
Well boys and girls, i posted to 31s on Craigslist today. I am going to face my fears and turn my 2013 Gecko Jk into a lifted beast on 35s. Id like to go with an AEV 2.5 inch lift, duratrac 35s, regear from 3.21 to 4.10 and build my custom bumpers and use a free hood i got to make a badass project hood. No real motive for posting but im excited and need jeep community support. Any advice for me on making a DD turn to the wild side?
Old 12-19-2013 | 02:54 PM
Tooadvanced's Avatar
Sounds good but I would go ahead and regear to 4.56 if I were you. And since you'll need a new carrier up front might as well put a trutrac up front as well
Old 12-19-2013 | 03:37 PM
mikestoick's Avatar
truetrac? What is that?
Old 12-19-2013 | 04:16 PM
Cjsmith4's Avatar
Tru trac is a locker. People say if you are ever going to get lockers, do it while you are re-gearing because then you don't have to pay the labor twice to pull the axle apart.
Also, to put the 4:10s in, you have to get a new carrier for the front anyway so putting in the tru trac in would be one way to do that and you'd get a locker on top of it all.
The question is do you really want a locker and would you use it.
I am looking at a re-gear currently and deciding if I want to get a locker or not. Have to get quotes and see what prices are with and without the tru trac.
Old 12-19-2013 | 04:21 PM
Not a locker but rather an awesome limited slip. With the 3.21 gear ratio you'll need to get a new carrier so instead of wasting money on a new open carrier I would just get a limited slip up front. It will increase your offroad prowlness quite a bit
Old 12-19-2013 | 04:35 PM
Gman*2007's Avatar
Good luck on your build.
Old 12-19-2013 | 04:41 PM
Cjsmith4's Avatar
Right. I should not have said locker as it is not actually a locker. If you google trutrac, here is what comes up and it's a great explanation of the workings of the trutrac.
http://www.eaton.com/Eaton/ProductsS...als/PCT_317264
Old 12-19-2013 | 08:07 PM
mikestoick's Avatar
Yea id probably do all work by myself. And i would do lockers. Trying to learn the difference in lockers tho. I know i want to select between lock and unlock at the press of a button. .
Old 12-19-2013 | 08:25 PM
mikestoick's Avatar
After looking real wuick i think i would just want to go with full lockers like whatever comes in a rudi. 100% to all tires or whatever. Seems like a limited slip is kinda half ass... Idk
Old 12-19-2013 | 08:28 PM
robsjeep9's Avatar
JK-Forum Ambassador
Consider the ARB air locker set up then... Great lockers
Quick Reply: The time to mod is comming
