Tie rod ends
Tie rod ends
What are some good heavy duty tie rod ends to go with?
What is an off set tie rod end? Is there a purpose for it being off set?
Former Vendor
You could go with some new Moog joints.....not sure there any more "heavy duty" than the factory ones at all. If your really looking to strengthen your steering you will need to replace the tie rod itself, which will allow you to run truly stronger ends. The RK tie rod will allow you to use a factory drag link end which is bigger and stronger. Also Synergy has a tie rod assemble that comes with nice strong TRE's.
