Tie Rod ends!!!!!!!!!!!
Okay so I bought a Rock Krawler HD tie Rod cause I bent the crappy stock one. Go to order the drag link ends(rock crawler suggests that P/N) and find out that up here in Canada they want....get ready $95 each!!! What the fawk?
So I have searched but cant find if there is any aftermarket ends for the RK Gen 2 HD tie rod......thanks
Just went through the same thing. I purchased MOOG PN# ES3624 through a MOOG authorized dealer around here it O'Rylies auto parts not sure what might be in your area they sell for about $23~$24 US dollars or so might try same company's website don't know what shipping might be.
okay thanks alot......By the time I add up cost, I could get a high steer kit with HD draglink,Tie Rod made from a shop near me Including 1ton ends for a bout 200 more
Both MOOG and Crown make the end links to fit the Rock Krawler HD Tie Rod. What I'd like to do is throw a set of Heim joints on it but there's little clearance even with the TeraFlex Drag Link Flip kit. So maybe once I go to the Reid Knuckles it will work. Remember the End Links for the RK are the Drag Link ones not the OEM tie rod ends which are too small.
Did a little research on this before. I've added the link. Look at post #4 for Moog #'s. The prices were from Lordco.
https://www.jk-forum.com/forums/show...to-be-replaced
Hope this helps.
Hope this helps.
Hope this helps.
Hope this helps.
