Thump/Pop when turning or stopping?
Hello,
Today after a normal turn at slow speeds in a parking lot I now have what I describe as a thump or pop sound when turning or stopping( I can feel it as well). I want to say it's from the rear but I'm not 100%, so basically a change in momentum/direction causes this noise.
I have a 3.5 inch Clayton lift with 35s. ( going on 4 years ). I have not made any changes recently.
Looking through other smilar threads I did the following tonight. In the hopes other people solutions would solve my own.
- checked ball joins and they seem good
- torqued track bar/mount front and rear
- torqued control arms
- checked exaust mount
- sway bar links front and back
- shock mounts all around
- gave everything a good heave-ho and nothing seemed loose
- did not see any signs of something comming to contact with another part.
- no burning smell
It's not my jack or any cannon balls rolling around in the back either...
First and foremost is it safe to keep on driving it? I'm use to my Jeep making noise but this seem like some serious friction sonewhere.
Second any ideas what's going on?
Thanks for any help.
- no burning smell
If it Did it just once I wouldn't worry about it too much since you check everything It could have something to do with the track bar But if it did it on every turn then I would be seriously looking into something.good luck keep us posted on what's going on.
Thanks for the quick response, but alas it has been thumping/popping almost every hard slow speed turn and some stops.
I was having a similar problem with my jeep. So what I did was I had my girlfriend hang on to the side of my jeep and rock it side to side. So while she was doing that I crawled under the front of Jeep and listened to where it was coming from. So I located it was coming from the front driver side. So I felt around to feel where it was popping. And low and behold it was the driver side sway bar connection and it was slightly loose. I couldn't tell other wise with out doing that.
And my problem started with me going to the dunes without disconnecting the front sway bar. Oh well :shrug:
when i apply brake when turning offroad or hard braking on street. i get a crazy vibration and shaking on my brake pedal and i can feel it threw the floorboard. this is only when i apply breaking
I did jack up the rear and and give the rubbers a spin to feel for any binding, nothing. However on the rear passenger tire if I pull/push on the top and bottom I do feel some movement and hear some noise ( the same way I know to check for ball joints up front ) I repeated this step for the drivers side and there was no movement or noise.
I know nothing about rear axel issues, so I'm going to try to educate my self now, but does any one think this could be the cause of my problems? Is it safe to keep driving around for the next day or two while I read up on how to fix it? Is this a one man, do it your self fix?
Thanks again fellas.
Sponsoring Vendor
Thanks for the help, I thought for sure you figured it out, but I set up a camera and recorded for any movement at either end, but there was no movement.
