Throttle Body Spacer????? Worth it? or not?
Many have and the benefit is at a very high rpm, and that is MINIMAL benefit. When you add volume to the intake you will lose low end torque (lose air speed, what we use most). It's like a sea-saw. Overall it's useless to the 3.8L, no benefit, they are good money waster and noise makers though...
This holds true for most of today's engines. Carb spacers used to work because it promoted air/fuel to the engine. Again, high rpm gain, low end drop...
My guess as to why it has a low end throttle response gain is with the throttle blade at the near closed position at idle air entering the manifold moves through the throttle body at the edges, hitting the swirl cuts on the tbs introduces more turbulent air into manifold. Open the throttle body blade more and the quantity of air running over the swirl portion of the TBS becomes less of a percentage of air entering the manifold. At higher rpms the air in the intake manifold is already turbulent and chaotic because of the increased frequency of intake strokes of the cylinders. This leads to absolutely no perceivable gains at higher rpms.
So anyway, to wrap this up, there are some noticeable gains in throttle response at low rpm which are seemingly all used up before hitting 1500 rpm. I have never heard the whistling others have mentioned and I can only guess it must come at higher rpms where the throttle blade is nearly closed and lots of negative pressure in the manifold. Most of all, this isn't something you want to spend your money on.
