Thoughts on these PR44 set ups
I went with the PR44 with RCV axles, ARB locker and Yukon gears 5.13 (2012 with 37's)
I've been running this setup for two years now and I've pushed it pretty hard and have been very happy with it
I did have to replace the Synergy ball joints with the Dynatrac rebuildable ones
Matthew
Matthew
I went with the PR44 with RCV axles, ARB locker and Yukon gears 5.13 (2012 with 37's) I've been running this setup for two years now and I've pushed it pretty hard and have been very happy with it I did have to replace the Synergy ball joints with the Dynatrac rebuildable ones Matthew
My Synergies lasted 6 months. The same is being seen with most aftermarket ball joints, even the Dynatrac. While there is not enough data to be conclusive, it appears the OEM joints work the best. As I have noted many times, the limitation is the size of the ball joint. There really isn't much you can do when you are running tires that far exceed the size the ball joint was designed for.
