View Poll Results: Did you drain the fluids before unbolting the pans?
I did the tranny with fluid in and no issue
0
0%
I did the oil pan with fluid in and no issue
0
0%
I did them both with no issue
4
100.00%
I did the tranny with fluid in and took a bath
0
0%
I did the oil pan with fluid in and took a bath
0
0%
I didn't learn from the first, and took a bath on both
0
0%
Voters: 4. You may not vote on this poll
For those who installed thier EVO MFG ProTeK Skid System
pretty straightforward question, did you drain your tranny and oil before you unbolted the covers, or did you do it with the fluid in there? Just wondering what my odds of taking a bath with tranny fluid and oil are.
https://www.jk-forum.com/forums/jk-s...-198955/page9/
This question is specific to the 2007-2011 Jeeps as the skid kit from EVO comes with a tranny pan cover much like the oil pan cover.
I did not drain the engine oil. In fact I just did my first oil change the other day, and the skids were installed before that. No issues at all doing the oil change with the oil pan skid in place. My JK only has 1200 miles on it, so no, I did not drain or change the tranny fluid.
I didn't drain the oil either for the engine. I just had my buddy hold the pan just in case it came loose but it didn't. Just be careful not to hit the oil pan with the skid plate cuz it could knock it loose and spill oil everywhere.
I understand being a little concerned about the oil pan but I'm not quite sure where in the installation you should be concerned about the tranny fluid.
