Those with D60's
Old 02-20-2015 | 02:30 PM
  #41
Invest2m4's Avatar
Originally Posted by Maertz
I would suggest a 14b or the sterling rear. I have heard the sterling rears are a nightmare to set up gears. Primarily due to the newer materials used on the crush sleeves. Not sure if they make pinion crush sleeve eliminator kits for that axle or not but if they do I'd highly recommend one.
There are a couple challenges with gears on the new sterling. First is that no one makes 10.5 gears (except Ford and they are stupid expensive and don't go above 4.xx). So, you get 10.25 hears and a spacer. Just have to know how to install in that particular situation.
Second, the crush sleeve is a beast. Takes something like 400 ft lbs.
Old 02-20-2015 | 06:27 PM
  #42
2climbbig's Avatar
My crush sleeve was a sench.. infact it was the easiest I delt with. let me check to see what install kit I used.
Old 02-20-2015 | 07:10 PM
  #43
2climbbig's Avatar
Ok, I found it. rock auto part number sdk317mk. It is made by SKF
Old 02-21-2015 | 06:23 AM
  #44
Waldo_88's Avatar
Best years for the 14b? Also, I assume they aren't the same lug pattern.. How big of a pain is it to get it converted?
Old 02-21-2015 | 06:33 AM
  #45
Maertz's Avatar
Newer the better. Preferably one that's already disc breaks. If i recall correctly they should also be 8x6.5. Read the 14 bolt bible on pirate
Old 02-21-2015 | 03:05 PM
  #46
Invest2m4's Avatar
That's why I went sterling as well. I just wanted consistent bolt pattern front and rear without modification.
The sterling is crazy strong and more clearance than a shaved 14 bolt. Also like how wide the new ones are.
Old 02-22-2015 | 02:04 PM
  #47
Waldo_88's Avatar
Is your sterling out of the same truck you got the front 60 from? 10.25 or 10.5?
Old 02-22-2015 | 02:12 PM
  #48
Waldo_88's Avatar
According to Pirate: "Axle Flange Bolt Pattern: 8 on 3.523", 1/2" holes, bolts are 1/2-NC13x1.5"" but other sites confirm 8x6.5
Old 02-22-2015 | 02:29 PM
  #49
Maertz's Avatar
i have 14 bolt hubs on my dana 60. The hubs are from a old drum 14 bolt, but i know for a fact they match the bolt pattern on my front. You may be correct though i think my front lugs may be a different thread/size than my rear. i think i have 9/16 and 1/2.
Old 02-22-2015 | 04:24 PM
  #50
Invest2m4's Avatar
Yeah, out of a 2010 F350. Sterling 10.5.
Quick Reply: Those with D60's
