Third brake light advice
Move you license plate to the spare like I did using a Rock Hard 4x4 relocation bracket then you can use a ORO Plate Lite. It has an LED 3rd brakelight plus a LED (looks like HID) license plate light. All for around $80 through 4wd.com, 4WheelParts, Quadratec or Northridge.
Install thread including wiring codes...https://www.jk-forum.com/forums/jk-write-ups-39/rock-hard-license-plate-relocation-bracket-oro-led-platelite-install-xrc-bumper-90672/
Running light only....
Just the plate light illuminated...
The LED brake light plus the plate light....
Brake light only....
Everything illuminated....
And some daylight shots...
JPTwinz...irronically, a buddy of mine had one the same setups as you have just lying around in his shed........and i was able to pick it up for the right price of FREE When I pull the old license plate holder off, is there plug that gets put behind it ????
Install thread including wiring codes...https://www.jk-forum.com/forums/showthread.php?t=90672
God the same setup on mine and everyone always asks where i go the light. east to wire and super bright
VA 3rd Light Law
I was just reading VA laws the other day and ever car since (if I remember right) 1986 has to have a 3rd light in the commonwealth of VA or else you will fail inspection or get a ticket if a cop sees it.
In 1986, the United States National Highway Traffic Safety Administration mandated that all new passenger cars have a third brake lamp installed.
Required on all new light trucks and vans starting in 1994.
That said, it's one of those things that you'll rarely get in trouble for.
I don't have one now, but I figure sooner or later I'll get a warning or a "fix-it" ticket. Until then, I'll keep running as is.
Although, if you get rear-ended and the guy behind you makes a fuss, you might be found liable for the accident. Something to at least think about.
Yes, there is a plug that fills in the hole left behind. I have the part number in my install thread. It costs about $13 from you Jeep dealer.
