thinking of going to 37s need advice
hey guys I am running now 35x12.5 on 18 inch rims I am thinking of going up to 37s my question is can I run 37s on stock rubi axles . I am running a set of 538s gears . thanks
You should be fine with them. Mostly depends on how you wheel. One of the best things you can add is gussets to your C's and if you wheel hard you can always sleeve your axle tube.
