Thinking about a higher Lift!!
That'll do it.
Add a BL though to save some uptravel/shorten the requirement for bumpstop extensions.
TeraFlex - How short a stack can the 4" lift coils compress to, and, are bumpstops required to prevent over compression...or just to fit 37's?
A 1" BL will only make room for 35's by itself....and there's no 2" JK BL's.
FT has there 4" lift that is shipping now. Your 3" ultimate can be easily upgraded to a 4" ultimate. I'm not sure of all of the parts needed, but If I remember right it is coils, and a pitman arm. I just added 4" rear coils this week.
(1) 9295 07 Jeep Wrangler Jk 2" in Body Lift
I stumbled across it doing an internet search...
The portal hubs lift the axle 4.5". You could run 37" tire on the stock suspension with a portal axle. They also have reduction gear in the hub itself so you could have 2.75 gears in the diffs and 2.0 in the hub for a total gear reduction of 5.5. You would be limited to the flex that a stock suspension provides but if ground clearance is you top priority then they would give you gobs of it.
Volvo uses them on their military vehicles and Mercedes uses them on their Unimog.
Here's a LR D90 on Volvo portal axles, notice the ground clearance
