Thinking about attempting gear swap.
#21
#23
Originally Posted by BrowniesJK
They looked good to me and the back lash is within spec so fingers crossed...
#24
Will do. I'm sure A-dub will be trying to bribe me as well. I'm going to bring home a 10' piece of 1" galvanized pipe to make a 5-6' breaker extension and I'm going to make a more stout flange wrench for future drinking events
#25
The 3/4 drive works much better no flex...and safer, I've broke a few 1/2 drive bars and it wasn't that pretty at all !
And Congratulations on your job that appears well done!
#27
Did my install yesterday. It was.my first install but it went well. The only issues was the bolt for the ring gear. Other then that we didn't use a case spreader. And I made a pinoin hold back tool. We used and impact to get our pinoin bearings set. Then used a huge beamed bar and pipe to get the crush sleeve to crush. It was a fun job. If you are very good about following steps and thinking logically its not that bad of a job.
#28
I am trying to regear as well but cannot get my head around shimming the main carrier to get the correct backlash with the 5.13 ratio. There are two main carrier shims which are used to get the correct backlash for the factory set 3.73 ratio, how did you subsequently shim the main carrier for the new ratio????? I cannot get any shims in-between the factor shims of the main carrier. OK I don't have a case spreader, but should I use this for shimming the main carrier?
I also thought about not using the large OD/ID 2+mm factory carrier shims but than I don't have enough shims in the overhaul kit, what I am missing here...........:thin king:
#29
#30
You are shunning to set your backlash for the gear set, not because the 5.13 vs 3.73. What you do is use the factory shine to test fit and.check backlash. If your backlash is to tight...under.006 then you need to shim the carrier away from the pinion. If your to loose .012 or more then shim the carrier closer to the pinion.
Here's what I did. I installed the new gears with the factory shims. My left shim was .135 and my right was .125 from the factory. My backlash was almost zero, at .001. I know if I move my carrier away from the pinion .010 then I should see a .007 increase in backlash. So I swapped my factory shims and that moved my ring gear away from my pinion and gave me a backlash of .008. This was with in spec.
The important thing to remember is that you have to think through it. You should have all the shims you need in your kit. Also testing the preload on your carrier with the factory shims is a good start. If you have good preload add the two shim thinkness together. In my case .125 + .135 = .260. When I move the ring gear around my total shim thinkness should still be .260, you just have diffirent ways to get it. Example .115 (left) + .145 (right) still gives me .260 total and the same amount of preload. But your ring gear is now closer to your pinion. See... I hope this helps.
