Are these the right Soft 8's?
Looking to do my lift and tires soon. I want to go to 15" wheels for my offroad set up. Will these fit my 08 x stick with the teraflex 2.5 coil lift and 35x12.5x15 tires?
5x5 lug pattern
Brand: Cragar
Product Line: Cragar Soft 8 Wheels
Part Type: Wheels
Part Number: CRR-3975850
Rim Diameter (in): 15 in.
Rim Width (in): 8.00 in.
Backspacing (in): 4.000 in.
Offset (mm): -12.00mm
Wheel Material: Steel
Wheel Finish: Black
Wheel Construction: 2-piece
Beadlock Included: No
Beadlock Functional: No
Lug Nut Seat Style: Conical seat - 60 degree
Lug Nut Shank Diameter (in): in.
Washer Outside Diameter (in): in.
Hub Centric: No
Center Bore Diameter (in): 3.300 in.
Center Cap Included: No
Valve Stems Included: No
Quantity: Sold individually.
5x5 lug pattern
Brand: Cragar
Part Type: Wheels
Wheel Finish: Black
Hub Centric: No
I would be a little concerned with the 15" rim. It would probably better if you went for the 16" rims.
Steel rims vary widley in production meaning someone can have a 15" steelie rub, while another person will have them rub on the caliper.
for instance, I have 16" rims and they fit, but with a lot less clearance than I had originally thought between the rim and caliper, but they fit--and they fit just fine. Now the 15" rims...well im not too sure about--I know people have some success running them, buts its hit or miss.
the rest of the specs of those wheels are just fiine.
these are the exact wheels I have, and they fit with no issues whatsoever. although I think they did rub the calipers on some of the JK's out there its a hit and miss thing.
some of the people that had them rub just grinded their calipers slightly...
2 questions:
1) how much caliper grinding are we talking about. If it's just a little thats ok i understand the whole chalk test principle but could it be enough that i might damage the caliper?
2) the rims from summit are about $38 a peice how much are the pro comps? I don't have a whole lot of money to spend.
2 questions:
