TF Lift on 2011 4door
#21
I'm assuming i will run into this issue when I install the 2 inch puck on the front from my leveling kit? Should i leave the bracket loose after install or try to reconnect? Thanks.
#22
#23
Bump this up!! Has anyone found a good fix besides replacing brakelines. I've got to get this issue fixed and I'm on the verge of just buying the brakelines, but this has been an ongoing thing on the newer jeeps, I think that someone should have come up with a fix. Or I guess all lifts need extended brakelines on the front. And if your gonna do the fronts and bleed the brakes, why not just do all 4?!?
