TF Lift on 2011 4door
Old 07-27-2011, 08:03 AM
  #21
Ron_Swanson's Avatar
I'm assuming i will run into this issue when I install the 2 inch puck on the front from my leveling kit? Should i leave the bracket loose after install or try to reconnect? Thanks.
Old 07-27-2011, 08:35 AM
  #22
awesomo's Avatar
I cut mine off with a dremel: https://www.jk-forum.com/forums/show...=1#post2373311
Old 05-12-2013, 12:20 PM
  #23
JLsJK's Avatar
Bump this up!! Has anyone found a good fix besides replacing brakelines. I've got to get this issue fixed and I'm on the verge of just buying the brakelines, but this has been an ongoing thing on the newer jeeps, I think that someone should have come up with a fix. Or I guess all lifts need extended brakelines on the front. And if your gonna do the fronts and bleed the brakes, why not just do all 4?!?
Quick Reply: TF Lift on 2011 4door
