TF Lift on 2011 4door
I ended up making extensions for the brackets out of home depot parts for $10. This raised the brackets about 3", compensating for the lift and keeping the lines permanently clear of the springs. I believe this is what the kit should do also.
![](http://i76.photobucket.com/albums/j18/Biginboca/IMAG0351.jpg)
![eek 2](https://www.jk-forum.com/forums/images/smilies/sSc_eek2.gif)
After reading this post I went and looked at my 2.5" BB with spacers on my 2011. While the front brake lines have a little extra length with the bracket installed, there doesn't appear to be near enough length to deal with a disconnected stabilizer off-road. I'm sure glad I didn't go off-road before realizing this problem existed. I guess I'll follow this post for awhile and then pick the best long term solution before going off-road.
This is what mine looks like after cutting the bracket off the brake line and rerouting it behind the shock. (previously mounted on the red arrow)
A dremmel was used to carefully cut the machine-pressed bracket that was around the brake line; I should have taken a 'before' picture. Now the lines are just free floating....
![sad2](https://www.jk-forum.com/forums/images/smilies/grayno.gif)
FYI, here is a pic of what the 2.5" coil lift with the factory line set up (no bracket extensions or removing the bracket) looks like under flex on the 2011. This pic was taken by another member about 5 months ago and posted in one of the other threads on this topic. It is worth noting that this pic is during install and there is no shock limiting his droop, but my kit with shock extensions made my lines look similar to this when flexed...
![](http://i76.photobucket.com/albums/j18/Biginboca/p1000117g.jpg)
Sponsoring Manufacturer
I am running your 2.5" coil lift and love it, so don't take this the wrong way but I do not find this to be an adequate solution for my 2011. When I tried this it looked like the lines (abs and brake) could slip inside the spring and get pinched by the coils as they compress.
Look at the pictures of the drooping break line behind the shock on Awesomes post. If you turn the wheel hard to the left the break line will droop even more and can get caught under the shock bracket. Verified this on my 2011 with a 2.5" lift. Then with a little extension and articulation off-road the brake line will become taught with the weight of the axle and potentially break. The only solution I'm comfortable with right now is to leave the break line in front of the shock and build an extension bracket like the one shown earlier on this forum. Before I accomplish this on Saturday I'll be checking to see what thoughts and ideas show up on this post.
