TF leveling kit+35"s ?
Originally Posted by rdubb1031
He's referring to the pinch seam weld, I believe, and yes there is a good chance this will come in to play. do a search, most people cut it off or bend it with a BFH. Sand, paint and you're good.. easy mod..
Yes to your pinch seam question, directly in front of the rear tire is what they're talking about. I have a pic of mine with 35's and there is 1" of space on level ground.
To your bumper, is it possible for you to clip the ends of it? I think it'd be fine for straight driving but I'm thinking that when you turn that you'll contact it there (if you can visualize the mass of tire rotating there. Also, think about how much your nose drops when you drop it into reverse. Are you going to be able to turn and put it in reverse??
My stubby bumper alleviated these issues for me so I can't say for sure if you'll rub or not.
Pics to maybe help
this was just 4dr coils, wheel spacers, and obviously my stubby bumper.
Try to draw a line down from the flare, unfortunately these are the only pics I have on the phone.
Pics to maybe help
![Thinking](https://www.jk-forum.com/forums/images/smilies/thinking.gif)
Pics to maybe help
Pics to maybe help
Do i need bumpstops ?
And can i offroad it on the sand at least without the flat fenders
Thank you , your jk looks sweet with 35"s
It depends how your sand wheeling is. Honestly- here it is really flat and there isn't a lot of suspension travel needed. So I would absolutely get the leveling kit and run 35's up and down the beach all day. You'll want bumpstops to keep the tires off of your fenders but if it doesn't bother you then you don't 'need; bumpstops. With the rubi wheels and wheel spacers I had no rubbing on seay bar links or any os the suspension on flat ground.
This was a very temporary situation since they're actually my friend's tires but he was nice enough to let me borrow them for a day to see how it would work. As far as flat fenders go, they are needed when you are doing some crazy flex but you have no desire to rub your flares. Again, to be honest- if I rip off a flare then I wouldn't much mind. But clipping your stock fender flares will achieve the same end result.
Now if you're doing jumps and all that in kuwait then you will really want the bumpstops and such.
Is yours 6-speed or auto ? And what gears?
I wont do any flexing before i put the flat fenders on but if i did some without disconnecting the links how bad will it be for the stock flares ?
And do i need bumpstops with the flat flares for extreme flexing ?
And thank you very much
![Thumb](https://www.jk-forum.com/forums/images/smilies/thumb.gif)
I have a TF leveling kit, 35x12.5 MTR's and flat fenders and there is 0 rub, even at full flex disconnected. I also drove around a bit with this setup before I got the fenders and around town, you are fine and will not rub.
If you disconnect when on the dunes, you will rub your fenders.
On my setup, I did NOT put longer bumpstops on and it is fine. I also added shock extensions and brake extensions to maximum articulation. About the only limiter on this setup is the approach and departure angle. I flatten my tailpipe at nearly every rocky excursion!
As for the gear questions. I upgraded to 4.88 (I have a 6 speed as well). For me, stock was 4.10 and that wasn't horrible. A bit sluggish, but not horrible. 4.88's really woke it up though and I have plenty of power up and down hills. Gas millage.... about 14-15mpg and running at 3000 rpm's at 70....
Josh
Josh
Josh
Josh
I think ill go for it , i dont care that much about gas milage
Can you post pics of your jk with the flat fenders?
Thank you
Here is a link to the thread with pics of my install: https://www.jk-forum.com/forums/show...ng-Kit-oh-yeah...
Also, my Jeep started life as a Sahara as well. I didn't think I had 4.10's until my installer called me to ask if I still wanted the 4.88's. I was a bit shocked to say the least.
Josh
Josh
Josh
Josh
