TF Level kit & 305's w/ spacers???
Some of it depends on your shock length too. Pkess3 was running really long shocks that make the axle droop more and make rubbing more likely as one side droops and one side stuffs the axle twists more as the shock length gets longer. More twisting means more likely to rub. If you had shorter shocks you might be able to get away with 34s without rubbing. There are guys running 35s at stock height with trimmed fenders and pinch seams and bump stops. A lot depends on the details of your setup.
I run 305-70-17 Goodyear MTrs with RC 3.25 lift kit and I had to trim rock rail and extend bump stops because I was getting rubbing. This was only off road though. I think u would be fine with 1.5 kit if u extend bump stops and are not opposed to flat fender/trimmed stock fender. U would def have to trim pinch seam as well.
