TF coil leveling kit + spacers
I have a jku with a TF coil leveling kit but wondering if I could add 1 inch spacers all around to get so more clearance. Would that effect the sway bar discos?? Thanks
Sure you can. But, with extra height comes more issues that you may or may not need to address. Caster/pinion, swaybars angled down, stretched brakelines, extended shocks, steeper driveshaft angles, offset axles, etc. Taller lifts tend to come with extra components for a reason, research a bit so you know what they all do so that you can make some more informed decisions.
Your caster angle numbers would be on your alignment sheet. Its probably low with your 1.5. If you went up a 2.5 it would be really off.
