TF 4 Door 2.5" Coil Lift on 2 Door
#21
I ended up with the TF 2.5'' 2DR lift. I'm not sure what I ended up netting but I have a good amount of room for my 35'' km2 (33.5'' mounted) under the factory flares even with my heavy mopar rock krawler bumpers, winch, and 100lb subs in the back. I did add a .75'' spacer in the front to level it out a bit. If i could go back the only thing I think i'd want to change is put a .5'' spacer in the front instead of the .75''.
#22
I just finished this very install this afternoon. I have a heavy front bumper so I'm guessing that I had some spring sag originally but, in the front it raised it 4.5 inches and in the rear it came up 3 inches. I did install adjustible track bars front and rear and control arm relocation brackets, and extended the front break lines. I have only driven it about ten miles sense it got done but I did get it up to about 75mph. It rides different but I can't say if its better or worse, just different. I do love the way it looks though. Now I just need some 35's. I have pics if youd like
