TF 2.5 lift w/TF 3" front coils?
JK Rocker, heavy ass winch and bumper in frt. It's not exactly the same, but he is running the TF 3in coils in frt and the TF 2.5 BB spacer in the rear. It sets pretty damn level. I had helped him do the BB, acouple months later, he rolls up to my house looking like a hot rod with his frt riding on bumpstops
He had talked to David at Northridge and explained his set-up. He suggested the TF 3in springs for the front. Rocker also has an XRC bumper tire carrier on the rear, with the BB spacers on stock springs, so far it's working.
Attachment 29035
Attachment 29035
yes the TF 2.5" coils will hold better than stock coils with 2.5" spacer. Go with the 2.5" coils all the way around... I added a 3/4" coils spacer up front to help with the ~200lbs of RR bumper and superwinch and it sits just fine. I think the 3" coils (more like 4+") will be too tall up front. Your best bet is to contact TF and get their opinion ...
I have a Warn 8274-50 with Warn HD mounting plate on my Rubicon Unlimited. I also have a Tera 2.5 inch coil lift. No sag. If the 200 Lbs of stuff doesn't make mine sag, yours won't either.
Flash
Flash
yes I have coils all the way around.. flash1034 and others... thanks I think I will be fine as is. If you have 200 lbs and no sag I am sure the winch doesn't weigh over 100lbs... I should be good.
