TF 2.5" front 1" rear ???
i am having the same issue. Daystar makes a 1 &3/4" Spacer or 3/4" spacer i can't find a 1" either. I have the TF 2.5" Spring & it still sits about 1/2" lower in front i prefer up in front. so once i get the winch & Body Armor front bumper. They have a new bumper with winch plate for $400 check it out. i will need to add a spacer in front. also will be adding ext. brake lines. don't know if any of this helps
I can't find anyone who makes a 1.5" rear though... does anyone know if the removing the rear stock isolator will give 1.5" of lift with a 1 3/4" spacer as noted above? Better yet; what is the stock isolator?
I would not remove any isolators.
Have you considered an OME HD front and regular OME rear? If that does not level it out, you could throw on a 3/4" spacer up front.
I have a stubby + winch up front and a steel full width + carrier in the rear. I went OME HD front/rear + 3/4" spacer up front. Level and I love it!
I've thought about HD springs up front, but with Rubicon tires and no plans to go bigger in the near future I don't want too much lift. just thinking the easiest and cheapest way to go for now is through a 1.5" spacer in the rear and have the look of the TF leveling kit plus .5"
I currently have a 2.5" TF spacer in the front with nothing in the rear...I've got a bumper and winch combo...I also am running xenon's...My jeep sits just over level. I didnt do anything else...but thats all getting ready to change..Ohhh, and I was running the Rubi wheels and tires...no issues
Thanks!
thanks, i didn't think that sounded like the best idea.
http://i754.photobucket.com/albums/x...1016091354.jpg
Hope this helps, also I just recently got the hood bounce @ 75mph and a very strong headwind...but other than that drives perfectly no issues...
