TF 2.5 Coil + OME Long Travel Shocks
Hey guys, just finished ordering my lift components:
TF 2.5 coil lift
Spidertrax 1.5" Wheel Spacers
TF front lower adj. control arms
JKS Front + Rear Adj. Track Bars
OME LT shocks
I am trying to build this rig up for reliability as it is my DD (Over an hour highway commute every day), but also for performance. Dave at Northridge told me he recommended using the OME LT shocks in place of their standard size as he believed they would be too small. Is anyone else running these shocks in combination with the TF 2.5? If so what are your opinions? Any other suggestions for my rig?
Thanks guys,
and thanks Dave for the great deal you gave.
TF 2.5 coil lift
OME LT shocks
Thanks guys,
TF 2.5 coil lift
OME LT shocks
Thanks guys,
TF 2.5 coil lift
OME LT shocks
Thanks guys,
PDF file from arbusa: http://www.arbusa.com/uploads/PDF/ac...WranglerJK.pdf
"Extended length shocks are for 4-6" suspension lifts only and are not intended for use with any Old Man Emu systems. Extended bump stops are required."
Are OME Extended length shocks the same as OME LT (long travel) shocks?
Maybe Dave at Northridge could chime in to explain the difference?
I'm lost here.. I just bought the OME nitro sports for my TF2.5 the (2-2.5 inch).. are those LT shocks? I'm confused, should I have gone bigger?
sorry for the noob question
if your shocks are marked 'LT' then you have long travel shocks. Sport vs Standard has to do with stifness.
