Terrible Wobble
Terrible Wobble
I replaced some stiff 4" procomp springs with some 4.5" synergy springs. It lifted it almost another inch. Immediately I developed a wobble when I hit a bump that is hard to keep on the road. Not sure if I would consider it death wobble but it's scary. I immediately thought track bar but after replacing the bushings no change. The ball joints are only a few months old and all the track bars are in good shape. No difference in the camber that I can tell. It's only a little more lift than what I've had for 3 years so I'm thinking next about the drag link. It's pretty sloppy but havnt had any noticeable issues at all, or maybe the steering stabilizer. Which one would you guys chase after next?
Forum Tech Advisor
Drang link, caster, alignment, and check every bolt in the suspension for anything loose. If its not doing it untill you hit a hole or dip in the road its not your tires. And if you cant find anthing or give up hydro assist will take it away lol <-- dont give up
